Help with converting RFT 7151 to use external power supply
« on: January 11, 2021, 06:06:42 PM »
Hello! First post here, but happy to be part of this forum  :)
A while ago I acquired an old RFT 7151 tube bottle microphone in non working condition. It seems to have been attempted to be recapped at some point, but seems incomplete as there are a few loose wires floating around inside it. My plan is to rebuild / rewire it, replace the selenium rectifier with a diode bridge, and remove the power transformer and related circuitry and locate it in an external enclosure to reduce mains hum.
I know vaguely what I need to do, but I have never done any kind of power supply design, so I thought I'd better check with some people who know what they're doing. My guess is that the two mains input pins on the mic will become one high voltage pin ( ~200V DC ) and the other with be low voltage for the heaters ( ~6.3V DC ). The power transformer will be moved into the external supply along with the filtering caps and the bridge rectifier. I'm also guessing that the 6.3V for the heaters will need its own bridge rectifier, and they will be run on DC rather than AC. Also do you think I should I use the original power transformer, or get a modern replacement?
Anyway, if anyone has some resources for this I'm be extremely happy to have them. From what I've read this is a common modification, and I'd rather not reinvent the wheel. I've attached the schematic for anyone who is interested in helping.
Trent
Re: Help with converting RFT 7151 to use external power supply
« Reply #1 on: January 11, 2021, 06:46:55 PM »
don't waste your time with the original 220 VAC input power transformer.
get a 200 VDC linear for the B+,
https://www.mouser.com/ProductDetail/International-Power/IHB200-012/?qs=0xCm9DOQnC7%252BW4SCa00vHA%3D%3D,
and either find a 12 VDC linear,
or build what you need.
re-worked many, with the original EF12k or 6072 tube fitted.
« Last Edit: January 11, 2021, 06:51:53 PM by gridcurrent »
ubxf
« Reply #2 on: January 11, 2021, 09:51:08 PM »
a new power supply is definitely working well for me with this microphone.
« Reply #3 on: January 12, 2021, 04:27:20 PM »
Thanks for the replies! Does anyone know why the two heaters are run on different transformer taps? If anyone has a schematic for a regulated 6.3v DC supply that'd be a big help.
« Reply #4 on: January 12, 2021, 08:19:49 PM »
the 1st tube heater supply has a hum adjust control.
the 2nd tube has one side of the heater grounded.
less voltage drop in the cable if powering the series connected heaters on 12 VDC.
« Reply #5 on: January 13, 2021, 06:52:50 PM »
Do you know how big that linear power supply is? I'm planning on building all of this into an Analog Vibes tube mic psu enclosure, and I'm not sure exactly how much space I have to work with. I'd almost prefer to use a single plate/filament toroidal transformer with 200v and 6.2/12v secondaries, but I'm having a hard time finding an appropriate model other than the original one from the mic. All the ones I'm finding are too large and too many watts.
I'd also prefer a transformer with a center tapped primary so that it will work on both 120v and 240v mains.
I'm super not understanding the heater circuitry. I though they just needed 6.3v ac or dc pushed through them. Why is one side of the 2nd heater grounded?
Last post August 12, 2006, 09:29:19 AM
by Tillmann
Last post December 16, 2005, 11:07:57 AM
by Emperor Tomato Ketchup
Last post July 23, 2012, 01:13:57 PM
by zebra50
Last post May 10, 2018, 01:21:52 PM
by Louis Smith
