Just to be clear, you're putting the SS-1 between the mic and the THAT pre? With the polarity switch on the output, it's not clear why that would interact with something connected to the input.
Yes, the SS-1 is between the mic and the preamp. It requires phantom power, so that's really the only way to use it. I can't see how the polarity switch would matter in this case, unless this particular combination of gear somehow screws with the line input on the Audient. I didn't have anything else handy to plug into for comparison. This is made further odd by the fact that none of my other preamps, connected to the Audient the same way, exhibit this behavior when using the SS-1.
What are the DC voltages on the output pins 2 and 3. Just wondering what kind of offset's you're getting there.
52VDC on each pin with nothing plugged in.
Is it possible you have your HPF in? I'm sure you're aware that the corner frequency is gain dependent. For the highest gain position, the cutoff is going to be over 700 Hz. I have a THAT pre with a HPF just (two frequencies actually) like that but I only went up to maybe 250Hz or so in the highest gain position. I'm assuming you did that so that you could make the 1u a film cap. I like it but you have to know how it works.
That would not entirely surprise me as the culprit, since the HPF is gain dependent, and we're adding about 25dB right out of the starting gate. I did, however, not have the filter engaged. I confirmed this by actually switching it on, and immediately heard the difference.
As for my choice of cap, it was combination of what I had around and just picking one by ear. The math, as you've seen, says that's excessive for a HPF. I've been kicking around resizing it, but just haven't had the time to do it. This may just be the excuse I needed.
I suppose I could find a larger audio grade electrolytic of the same series as the big 3300uF. I haven't run the numbers yet, but is it possible that the extra 25dB of gain is sufficient to cause a roll-off even through that large a capacitor? Seems unlikely.
One of these days, I think I'll crack that SS-1 open and see what's going on in there. They claimed it does more than just boost levels, so who knows how many other "undocumented" filters are active here.
