Hello, everyone,
I am helping a friend with a Bogen MXM preamp/mixer that he is wanting to use for tracking. When he got it someone else had did some mods on it like replacing the filter switch with a pad and adding unbalanced direct outs on all of the channels which interrupts signal to the master. When tracking drums he said the inputs sounded overdriven which is fun on certain applications but not all. Since it's just going to be using as a mic preamp, I want reinstall the HPF and see about getting more headroom or padding the input to better accommodate recording drums. I've attached the schematic of the MXM-A which has a couple more features like the Hi-Z selectors, which this unit does not have. But the rest of it should be the same.
I was looking over the schematic and I noticed that the plate voltage to the 12AX7s on mic inputs 1-4 is 40V and I thought this was very low and that maybe this might be causing them to sound overloaded so easily if the plate is being starved of voltage. Would there a problem if I jumped R2, 8, 14, and 20 to get 185V for the plate like is shows for V3B?
I also noticed that there is no summing resistor network. Shouldn't there be one?
There is one problem that needs to be addressed before I get too far in the project. The master output has 4VDC between pin 3 and ground. There is also a very present 60 hum and the audio is severely high passed. The audio direct from each channel is correct, minus the headroom. The fun part is when I power the unit off it blasted my converter inputs with signal and I measure 53VDC and was dropping with the capacitors. I do not see how that is possible per the schematic. Granted I haven't begun to trace to see if the person whoever modded this unit missed something. It sounds almost like a bad transformer but I still don't know how DC is getting through. I may need to add an electrolytic inline to block DC but that won't fix the high pass issue. Any see something like this before?
Paul
