Is there a standard off the shelf +-15V or +-18V linear supply everyone uses?
ruffrecords said:Is there a standard off the shelf +-15V or +-18V linear supply everyone uses?
Considering the various opinions, the answer is clearly NO.ruffrecords said:Is there a standard off the shelf +-15V or +-18V linear supply everyone uses?
This is for a customer. I am building a mastering EQ with op amp input and output. I will test it using my bench supply. His tech will integrate into their enclosure and add a PSU. So many p[eople us op amps I thought the market would be awash with ready built off the shelf power supplies for them but when I came to look I did not find many. So I guess 100mA to 200mA will be sufficient. Definitely linear. Self contained, fully assembled, UL listed. US mains.Brian Roth said:What amount of current? 100 mA or 15A? <g>
Self-contained in an enclosure (and UL/whatever listed)? Linear or SMPS?
Fully assembled or kit?
I have suggestions for all the above.
Bri
pucho812 said:
That's what will make it expensive!ruffrecords said:UL listed. US mains.
Back in the 70s I sold a kit +/- 15V supply using 7815/7915 including transformer and line cord for only $15. Not UL approved so I would never try that now.abbey road d enfer said:Considering the various opinions, the answer is clearly NO.
Very early on, I made a PCB with a 7815/7915 pair (that was before LM317/337) and a PC-mounted xfmr and used it in all sorts of projects.
They can be found on Alibaba with MOQ's around 5 pieces...I might be willing to try them out as I've been looking for something like this to test preamp circuits.squarewave said:That has come up before but no one stocks them.
JohnRoberts said:Back in the 70s I sold a kit +/- 15V supply using 7815/7915 including transformer and line cord for only $15. Not UL approved so I would never try that now.
Not rocket science, these days I'd be inclined to consider AC to DC switching supply modules that are UL approved.
I used to use MeanWell modules for a huge console without any additional filtering, just local decoupling for every module. No problems. A linear would cost like my kidney for it.Rochey said:That's exactly where I am too. Better to take an approve module, and add some aggressive filtering!
Which model do you recall?dbelousov said:I used to use MeanWell modules for a huge console without any additional filtering, just local decoupling for every module. No problems.
