I found the documentation on the 2203 ,
the 'cal' pot basically allows the user to calibrate out the effects of the various supporting hardware that goes along with the measurement set , mic goose necks for instance add a specific capacitance which loads the response of the various capsules by a certain amount , each capsule has a given offset to begin with .
The model I got is older but externally identical to yours ,
and im sure spec is very much the same , its still light years beyond the spec of most microphones even 60 years on . The freq.resp with the various different parts is also so well documented , predictable and consistant from specimen to specimen its easy to account for its effect on the overall performance , this is very good news for using it with REW .
A stereo set up is the obvious application , spaced omni's with a super high bandwidth/dynamic range recording format , you just turn up at the cathedral or concert hall with a couple of mic stands and a hardcase
