For the longest time these were listed on their site with MOQ of ten pieces.
Now it looks like you can buy singles for about 140 bucks.
They have A-10, A-24, and A-26 models. I haven't had a chance to try them yet, but would be interested to hear if anyone else has.
Looks like they're also doing the Marinair LO-1166, 31267 and 10468 transformers, which I'm sure might be of interest to Neve cloners.
Re: AMI now offering single pieces of UTC-inspired transformers and others
« Reply #1 on: February 02, 2021, 01:57:24 PM »
Have wondered about those
« Reply #2 on: February 02, 2021, 05:01:19 PM »
 Where are you seeing this? This information is not reflected on their website.
Justin Heron
Artist / Recording Engineer
« Reply #3 on: February 02, 2021, 05:05:33 PM »
https://www.tab-funkenwerk.org/ami-parts/transformers/
rackmonkey
« Reply #4 on: February 02, 2021, 06:55:51 PM »
Good to hear they're finally getting to this. Thanks for the heads up. Hope they were able to stay true to Oli's designs.
Whether you think you can or you think you can't, you're probably right.
« Reply #5 on: February 04, 2021, 08:24:04 AM »
I must have clicked on an old link or something. This is soo exciting! I can't wait to try out the UT10 in my DLA2A!!
Justin Heron
shabtek
« Reply #6 on: February 04, 2021, 10:22:47 AM »
their a-10 curves don't resemble the utc version
edit
sorry Bonnie! you are correct test conditions are different
« Last Edit: February 04, 2021, 11:24:36 AM by shabtek »
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
« Reply #7 on: February 04, 2021, 11:15:57 AM »
Hello Shabtek, not sure where your information on the original UTC A10 Freq. plot comes from?  However your statement is completely incorrect.  If you test under the same src/load conditions as defined on our graph you will see how incorrect your statement is.
Also possible, you have measured a defective A10. In our R&D we tested 5 different original UTC A10's, to confirm all the R&D Oliver had done.
In the coming weeks we intent to post comparison graphs on our site.  As it's been said "The proof is in the pudding".  Static measurements don't offer a complete picture and Oliver certainly had his own style when designing musical components.
Please..... the intent of me responding is not to be argumentative, only to state the facts!
« Reply #8 on: February 04, 2021, 11:32:09 AM »
edit
Was just coming here to point this out, as I went back and looked at your plots in the Crimson A-10 thread as well!
Would be really cool to see all three (UTC, Crimson, AMI) all tested together under the same conditions to see how they compare.
shabtek
« Reply #9 on: February 04, 2021, 11:43:28 AM »
Quote from: soapfoot
Would be really cool to see all three (UTC, Crimson, AMI) all tested together under the same conditions to see how they compare.[/quote
indeed, (foot in mouth) I suspect they will respond pretty close under same conditions.
my sweep was 600Ω source to 600Ω wind 100k load 0dBu out iirc  probably would be more realistic at +4 in
@Dennis: are you using the 200Ω primary connection in your sweep?
definitely
« Last Edit: February 04, 2021, 12:05:06 PM by shabtek »
   -CJ
« Reply #10 on: February 04, 2021, 01:17:10 PM »
"my sweep was 600Ω source to 600Ω wind 100k load 0dBu out iirc  probably would be more realistic at +4 in"
Hello Shabtek,
UT 10 test conditions
150Ω src / 100k Load, Input level +12dbu / Response level @ 1k +29dbu / Max output level w/ 1% THD @ 20 cycles = +17dbu.
« Reply #11 on: February 07, 2021, 07:53:22 AM »
Just ordered a UT10 for my LA2A to replace the Sowter 4383. Will report any noteworthy sonic changes.
Justin Heron
ElSmurf
« Reply #12 on: February 17, 2021, 06:58:21 AM »
I ordered the UT10 and UT24, as well as the NI73 and NO73 from them. Haven't finished my LA2A yet or put the other two in my ez1073, but they look (and smell) really good.
I have no comparison for the LA2A but I'll be very interested to hear the difference with the Carnhills in the ez1073.
« Reply #13 on: February 17, 2021, 11:21:48 AM »
One thing I'm interested in for a start is delivery time--the site now says small orders shipping in March.
I'd be inclined to try a pair of A-24s, but I'd need them fairly soon
« Reply #14 on: February 24, 2021, 08:47:10 AM »
 Just finished replacing my Sowter 4383 with the AMI UT10. Both transformers are very very good, but the AMI has the edge. I dare to say that the Sowter is just a little hazier, like an overcast day, the AMI is like a nice sunrise over morning dew beading off the grass; the Sowter like 35mm film in the 80's and the AMI like 35mm film in the 90's, but even this is a dramatic description. Tonally they don't seem too far off. The first thing I noticed was that the AMI added like 15db of gain, so I had to turn the gain knob way down to level match to my previous Sowter 4383 test tracks. I didn't do anything scientific, just using my ears and intuition.
 Another thing I did was change out my 12AX7's, I noticed one had a pretty low 60hz hum and was much noisier than the other tubes I tried. I don't know if it was the tube change or the transformer change, but the compression is so much smoother than it was before. I had to say goodbye to an Amperex Bugle boy, and changed it to an early 60's RCA, then the tube that I put in the sidechain is a sturdy Tung-Sol new production - almost no noise whatsoever.
 Would I notice much of a change in the output transformer? I am using a Carnhill VTB2291 for the output currently.
Justin Heron
« Reply #15 on: February 24, 2021, 11:59:02 AM »
The difference in gain is probably because the 4383 is a 1:4 and the UT10 is closer to 1:9
An apples-to-apples would probably be the Sowter 1449
Still interesting to hear your thoughts! I have a couple of AMI UT24 sitting here right now, very interested to hear them!
« Reply #16 on: February 25, 2021, 08:21:23 AM »
 What are you looking to put the UT24 in?
Justin Heron
« Reply #17 on: February 25, 2021, 11:55:53 AM »
Considering using it instead of Triad HS-50 as Pultec MEQ-5 output
Last post October 28, 2010, 05:30:26 PM
by matta
Last post January 29, 2014, 05:59:13 AM
by gary o
Last post June 23, 2018, 01:41:43 AM
by moltenwok
Last post December 04, 2019, 03:59:23 AM
by ward
