Looser giaphragm tends to give more low end, and more output of a capsule. Hovever in this case, with blind holes closed, i am afraid it might negate the effect of closing the holes, and might bring back some of the high end. But i am just guessing. Haven't tried with k67.
MXL603 type of capsules (cardioid and hyper) tend to have way to much tension on diaphragm, and therefore poor low end. I've modified them before by stretching diaphragms gently in circular motion with a q-tip against non coated side of diaphragm. I do it until i reach between 1-2khz. I check resonant frequency by blowing gently against them at an angle. They resonate clearly at fundamental frequency that way.
Keep in mind if you decide to try it, they gain back some tension after some minutes, or hours, so you might want to do it in stages.
