Not sure which data sheet you are reading but the E88CC one (which is the same tube) says its 150V (cathode positive wrt filament) and 100v if negative.CheersIan
RCA 6922 specifications 5-62: "Heater negative with respect to cathode max. 60 volts"Error in RCA sheet?Paul
Started by rafafredd The Lab
Started by SUPERMAGOO The Lab
Started by Larrchild « 1 2 ... 7 8 » Drawing Board
Started by shabtek The Lab
