Blue Jinn
For bipolar power supplies, specifically +/- 15VDC, I usually see an 18-0-18 or so transformer in the schematic. However, I just built one but get ~15v on the positive rail and ~20vdc on the negative. With a full wave bridge and 2200uF capacitors I'm getting about 30vdc at the input to the regulators. The datasheet indicates it should be no more -23v so I'm assuming that's the problem.
Using a 12.6-0-12.6 transformer I get ~15 on both rails. I've always read the transformer should be higher than the expected regulated voltage, but if voltage = 1.4x input just after a full wave bridge why? And with tube circuits it seems expected that the B+ voltage will be higher than the transformer voltage.
