Ordering Omeg Pots for Calrec EQ (and other project)
matta
Cape Town, South Africa
Hey Guys,
I ordered my pots for the Calrec EQ from Omeg, the ECO range.
It had been stated in a previous thread that you needed PC16ECO 10KB
with centre indent, this however I have found is a 10K LOG pot, but the
BOM/Parts list calls for a 10K LIN Pot.
The ECO 10K LIN Pot part no is actually PC16ECO 10KA.
I?m glad I found out as they were literally at the point of manufacturing,
but Margaret noticed that my description 10K LIN didn?t line up with the
part number, which was LOG.
Matt
I thought it was a LIN pot
It's for the "volume control" - I guess you want the volume control to go down and up in equal steps and not logarithmic steps
e.g. 50% of the way around you want 0db to be half way between say -10 and +10 (otherwise why bother buying a centre detent pot)
If it was a log pot it would probably be around the -4 ..
Christ - if I got that right - I think I might be on the beginning to start to understand this audio lark...
Hey Simon
I didn't install yet the Omeg pots into the Calrec boards so by curiosity, five minutes ago I measured the 10K pots at mid position.
One half a bit over 1Kohm and the other half a bit over 8Kohm. S H ! T ! We have log pots for level, and that is bad.
chrissugar
I wonder if this is why some guys are having gain issues with their Calrec?s?
I asked Margaret at OMEG the following question:
For my own peace of mind and others on the audio forum I am part of  please
confirm your lettering system works as follows:
A= LIN
B= LOG
C = REV. LOG
I want to post this info so other don't make the same mistake I 'almost' made.
Her response was as follows:
Yes Matt that is correct.
(I think the Far East do it slightly different).
All the best
Margaret
Hope that helps you guys!
Matt
I have 6.5 dB of gain across the whole spectrum. I used the linear pots. The log pots should present discrete areas of gain reduction at the four frequency centers. I think most folks with the gain increase are seeing full spectrum gains.
-Chris
Nope. No cheating possible here, I think. Need constant-impedance.
You'll need 10KA - that is Lin - for the Calreq.
Japan - and often US names lin. pots as e.g B10K for a 10K lin, whereas Europeans use the other order: 10KA
A centre-detent log. pot wouldn't really make sense, would it?
Jakob E.
HI ALL
SORRY ALL FOR THE BONEHEAD MISTAKE!! :oops: :oops:
I got my ALPS laws and my OMEG laws backasswards.
Alps A=log B=lin C= antilog.
Omeg A=lin B=log C=antilog.
MATTA IS RIGHT....OMEG part# PC16ECO 10KA
with centre detantes is correct for the lift/cuts. This
pot MUST be a LIN pot.
All of my posts have been updated and corrected.
Thanks Matta for the discovery and I hope none of
my friends here got hosed.
GARY
[quote author="gar381"]
GARY[/quote]
Only a group buy of 50 pieces!
My pocket will be stinging... my children will go hungry....
I am helping the guys out on this one...
No probs - my fault for not double checking
Anybody got any idea what I can do with 10k centre detent LOG pots??
