414 EB P48 with strange things and strange subs
mkiijam
T3 which is supposed to be a SK30 was replaced with a SK118. The weird thing is this: Whoever installed it shorted all the legs together. Now, this microphone "works" but has two issues (I think)
1. You can pick up a radio station. I have heard this is NOT normal and I can't pick up the station on any of my other condenser mics.
2. The output seems low to me. Certainly quieter than my other condensers.
When I "unshort" the 3 legs it doesn't work, just a bunch of crackle and pop.
Thoughts? Right sub for T3 / Sk30?
  • AKG-C414-p48.pdf
T3 is a constant current device
Look up the Id vs gate to source voltage (voltage difference the top of R9 and the "top" of R8)
Care to speculate why it works with all the legs shorted? Radio station?
speculate? It is a simple circuit
The NPN is an emitter follower with a CC circuit in the emitter part of the circuit instead of a resistor.
With the transistor shorted together you have a very bad design emitter follower using the wrong value resistance in the emitter circuit.
A link to a thread at this forum reply 97 might help
https://groupdiy.com/index.php?topic=75491.msg964588#msg964588
Great link, thank you.
My plan is this: To replace t3 with a 2N5457 and then maybe play around with R8 value until I achieve 45mA?
It's working now, but I'm still picking up a radio station! it seems to be coming in on the cable as if I move the cable around it will lower the radio station level.
Any thoughts on why?
R9 to R8 measures .755 Vdc
Actually, whatever the Vgs voltage, it's the voltage across R8 that matters. I believe it should be around 3V, for ca. 0.4mA quiescent current.
Regarding radio interference, it's probably not related. Check connections between body and ground, between  C17/18 and ground and continuity between basket and body.
Thanks. Across R8 measures 3.4Vdc. I have a 2N5457 in for T3 as I couldn't find any originals.
All of the grounds check okay.
I'm going to make a separate post asking for a reference level test. I need to know if the output level is within a reasonable amount and have no other 414 to use. My tests thoughts are these:
Someone with a 414 P48 and an SM57: Please play a 1kHz test tone through any speaker. Place SM57 1-2 feet away (but measure accurately and record the distance). Aim SM57 directly at the cone as best as possible and as square as possible. Record level in audio file or just let me level. Place 414 in same position as record level same way.
When I do these tests on my end I will place an SM57 and 414 and should get the same "RATIO" as you did IF my 414 has the right output?
That wouldn't be a very valid test, since a very small difference in placement can result in significant change in level when using sinewaves in an uncontrolled acoustic environment. You need pink noise or warbled sine. Most DAW's offer the possibility of pink noise. In order to minimize the effects of different frequency response, the pink noise should be filtered around 1kHz.
No need for anyone to make measurements.
The datasheets indicate a sensitivity of 1.9mV for the SM57, and 6 mV for the 414 in cardioid position.
That's a 10dB difference.
Okay. So the 414 should be 10dB louder at a given distance, blah, blah?
