Spencerleehorton
JTM45 / 50 Build
« on: February 23, 2021, 03:33:04 AM »
Hi All,
Now moving onto the JTM45 build from the success of the fender champ.
First of all I wanted to try and use this line 6 spider MK2 power txf.
I have the following voltages on it:
Winding 1 is 370vac with centre tap
Winding 2 is 60vac
Winding 3 is 20vac with centre tap
Winding 4 is 6.7vac but in 4 leads?
1+3 = 6.71v
1+4 = 6.73v
2+4 = 6.72v
2+3 = 6.71v
My issue seems to be on the 6.3v windings. (And yes I know I could just buy a 5v txf)
By process of elimination, would I be right in guessing that on winding 4, taps 1 and 2 could be the CT on the 6.3v windings?
I need one 5v winding and one 6.3v winding for this txf to work and wanted ideas to get the 5v?
Could I use a high wattage resistor to lower it?
My other option could be if I can split the centre tap of the 20v winding and then parallel the two 10v winds to give me 5v?
« Last Edit: March 14, 2021, 11:42:49 PM by Spencerleehorton »
website: www.mohawkstudios.co.uk
email: [email protected]
If it hisses its probably the wrong impedance!!!
Or a snake!!!
Spencerleehorton
Re: JTM45 Build
« Reply #1 on: February 23, 2021, 04:22:09 AM »
I could use a voltage divider of 10k and 6.8k to drop 1.47v, which would get me close but I'm also concern I dont know what wattage these 6.3v windings are?
Is there any tests I can do to establish was they are?
As I need I think at least 2A possibly 3A windings?
Be good to know a few more techniques on this if anyone could share please?
Or a snake!!!
abbey road d enfer
Re: JTM45 Build
« Reply #2 on: February 23, 2021, 04:36:16 AM »
You seem to ignore the basics. With 10k in series, tehre will be almost nothing when it is loaded with the rectifier filament. The GZ34 filament behaves like a 2.6 ohm resistor when hot. But when it starts cold, it's like a 0.2 ohm resistor.
That means it would receive about 6mA, which would never start it heating.
If you want to lower the voltage with a resistor, it should be about 0.68 ohm.
However I wouldn't recommend it, because the heater voltage may change when teh tube heats, maybe significantly enough to put it in unsafe operation area.
You must definitely learn about Ohm, Norton, Kirchoff & Thevenin.
Who's right or wrong is irrelevant. What matters is what's right or wrong.
Star ground is for electricians.
Spencerleehorton
Re: JTM45 Build
« Reply #3 on: February 23, 2021, 06:35:19 AM »
Yes my calculation attempt was way off, I am starting to learn it though!!
My second attempt I worked out that I needed 3.15ohms which would give me 2A, which would involve a 0.8ohm 5watt resistor!!
Or a snake!!!
Spencerleehorton
Re: JTM45 Build
« Reply #4 on: February 23, 2021, 06:44:06 AM »
I appreciate it is very frustrating reading my mindless attempts but I am trying to learn this, having been helped in the past I need to like you say get the basics right.
Ohms laws seems to makes sense now but I do need a lot more experience with it all as havent dealt with these particular calculations before.
Would you be able to explain the any possibilities of using this txf for this purpose please? How you would go about it and any calculations would be fantastic.
Or a snake!!!
Spencerleehorton
Re: JTM45 Build
« Reply #5 on: February 23, 2021, 09:18:04 AM »
So from what you have said, if I put a 2.6ohm resistor on one of the 6.3v windings then measure the voltage and see what I've got?
I think I have some 2.2ohm 2W , i definitely have some 7ohm 8watt.
Or a snake!!!
abbey road d enfer
Re: JTM45 Build
« Reply #6 on: February 23, 2021, 01:47:56 PM »
Please read again, carefully now.
0.68 ohm.
Spencerleehorton
Re: JTM45 Build
« Reply #7 on: February 23, 2021, 02:30:40 PM »
I'm not talking about within the circuit I'm talking about just testing the transformer.
So are you saying to test the txf just use a 0.68ohm resistor and see what voltage drop I get?
Or a snake!!!
abbey road d enfer
Re: JTM45 Build
« Reply #8 on: February 23, 2021, 05:15:31 PM »
With just one resistor and no load there is no voltage drop. The GZ34 must be in circuit.
Spencerleehorton
Re: JTM45 Build
« Reply #9 on: February 24, 2021, 12:43:36 AM »
My aim was to test this txf with a dummy load first, then see what voltage I had.
Just to be clear.
I took what you said about heater filament as if I'm testing without tube that the filament is 2.6ohm, then the load would be 0.68ohms to reduce down to 5v, so 3.2ohms total?
I dont mean to offend but you have not explained how you got to this, could you explain please?
« Last Edit: February 24, 2021, 01:52:08 AM by Spencerleehorton »
Or a snake!!!
Spencerleehorton
Re: JTM45 Build
« Reply #10 on: February 24, 2021, 07:31:02 AM »
Here is the turret board nearly complete!!
Cant upload any images as the uploads folder is full!!!
Or a snake!!!
abbey road d enfer
Re: JTM45 Build
« Reply #11 on: February 24, 2021, 04:41:06 PM »
Just to be clear.
5V 1.9A gives 2.6 ohms.
Drop 1.3V at 1.9A gives 0.68ohm.
Spencerleehorton
Re: JTM45 Build
« Reply #12 on: February 25, 2021, 01:22:47 AM »
Ok, well it seems I maybe able to move forward with this txf by the use of some diodes on the 6.3v winding to bring it to 5v, I just need to make sure that I have two completely separate 6.3v windings.
So one winding could heat the filaments at 6.3v and the other with two sets of two anti-parallel diodes rated to 5A connected in series with the rectifier filament. The diodes should be placed on a heatsink.
Thanx Milan for this.
Or a snake!!!
abbey road d enfer
Re: JTM45 Build
« Reply #13 on: February 25, 2021, 06:03:54 AM »
Simulation shows that with two sets of two diodes, the RMS voltage would be 4.9V; close enough.
You don't necessarily need two separate windings.
The diodes introduce some distortion of the voltage; how significant it is depends very much on the DCR of the xfmr and the sensitivity of the audio circuit.
Note that, even using a separate winding, the waveform would also be distorted, although slightly less.
Spencerleehorton
Re: JTM45 Build
« Reply #14 on: March 04, 2021, 01:59:14 AM »
Trying to post picture of turretboard.
Or a snake!!!
Spencerleehorton
Re: JTM45 Build
« Reply #15 on: March 08, 2021, 02:28:32 AM »
What's your thoughts on using 0.25w pots for this build?
Or a snake!!!
Spencerleehorton
Re: JTM45 Build
« Reply #16 on: March 11, 2021, 05:47:45 AM »
looking at possibly modding this circuit to a dirty shirley but unclear exactly what the changes are?
Anyone have any input please?
Or a snake!!!
Spencerleehorton
Re: JTM45 Build
« Reply #17 on: March 12, 2021, 01:48:03 AM »
This is the schematic I'm going to follow but I'm going to use diode bridge for B+ and will put diode bridge on the rectifier socket like what I did for the champ.
The output valves I have will be EL34s so there also maybe a few changes to components?
Will need to verify these changes.
Or a snake!!!
Spencerleehorton
Re: JTM45 Build
« Reply #18 on: March 12, 2021, 01:56:08 PM »
Its seems I may go for the JTM50 build and put switches on the cathode bias of V1a and V2a.
Will check that this power txf can get 320v ac so after the diode bridge I can get 440v dc.
Or a snake!!!
Spencerleehorton
Re: JTM45 Build
« Reply #19 on: March 14, 2021, 08:59:40 AM »
Just wondered if anyone knows if the cathode bypass capacitors sound better as electrolytic, tantalum, polyester or polypropylene?
Or does it not matter?
Or a snake!!!
Last post June 13, 2007, 05:04:17 PM
by CJ
Last post September 16, 2014, 12:57:11 AM
by cd27
Last post November 11, 2008, 09:02:23 AM
by API
Last post May 03, 2018, 11:59:03 AM
by nashkato
