Rocinante
Need just a few or one or two. .25 please
Rocinante said:Need just a few or one or two. .25 please
Rob Flinn said:Gar do some pretty good one for something like $7 each on their ebsite. They are very good.
Whoops said:What is Gar?
Whoops said:Any problem with these?
http://www.avdaudio.com/catalog.htm?pid=1376
ruffrecords said:They are all 6mm shaft. OP asked for 0.125 inch. Most (all?) API knobs are usually imperial.
Let me know how you get on drilling out the 0.25 inch. I tried this and was a few degrees off perfectly vertical. There is a very noticeable wobble on the couple I drilled out. I am not mechanically gifted in the least so it may just be me. I have half a dozen 6mm ones left if you want to save a little money.Rocinante said:I'm fine with drilling. And yep AVD had exactly what I wanted. Thanks gents.
ruffrecords said:Let me know how you get on drilling out the 0.25 inch. I tried this and was a few degrees off perfectly vertical. There is a very noticeable wobble on the couple I drilled out. I am not mechanically gifted in the least so it may just be me. I have half a dozen 6mm ones left if you want to save a little money.
ruffrecords said:I tried this and was a few degrees off perfectly vertical.
