Wilcox M57D1 tube limiter restoration
« on: February 28, 2021, 05:59:06 PM »
I'm working on restoring an ancient Wilcox tube compressor which was a part of a telecommunications console and was originally designed to limit a mic level input for transmission to telephone lines.  I managed to track down an Army manual that has a schematic, layout and other technical info.
The actual circuit & tube complement differs from the schematic.   Judging by the condition of the wiring it doesn't look to be user modified, I suspect the circuit was revised at some point and that the revisions aren't reflected in the technical docs I have.
Original schematic-
https://drive.google.com/file/d/1eTyulF8FcXRzW9gWDY7EThWg6KYNnXmW/view?usp=sharing
And my redrawn version-
https://drive.google.com/file/d/1sliy3OC_fLOdsgaRMpK5IiPAMa237qiw/view?usp=sharing
There's two chokes in the power supply, Kenyon input transformer, Stancor output transformer.  The labels on the interstage transformers aren't immediately visible.
In the original schematic the output stage was a 6SN7 but mine seems to be wired up for a pair of 6V6's (there is a metal label on the chassis with the tube lineup printed on it and 6V6 is scratched into the surface corresponding to those 2 sockets).
The only resistor that doesn't look original is R17 (6.8 meg).
I was surprised to find a dual 500k pot wired into the grids of the 6V6 output tubes.  It seems R16 sets some control over the threshold of compression.  I've never seen a tube compressor with 6SA7 tubes in the input stage.
Before firing it up I have some work to do in replacing the power filter capacitors, replacing the old connectors with XLR & attaching a proper power cord to it.  I'll also need to track down some 6SA7's.  The old cloth wiring is very brittle and cracks apart if I'm not extremely gentle with it.
Curious if anyone has worked with one of these before and any thoughts about the circuit?
jazzcrisis
Re: Wilcox M57D1 tube limiter restoration
« Reply #1 on: February 28, 2021, 06:27:19 PM »
Never seen or heard of one before, but looks like it has the potential to be a nice limiter. Should be reasonably fast too.
« Reply #2 on: February 28, 2021, 06:37:00 PM »
Wow, that's an odd hack, I would expect to see 6V6's used to get a higher ratio, yet they've tossed a gain stage to the side chain rectifier to get another socket free.  A pot on a power tube grid is problematic too.   2K cathode on a pair of 6V6's.....I could go on.
Picture of the unit in question?
« Reply #3 on: February 28, 2021, 06:42:57 PM »
That's my bad, I forgot to redraw the value there.  The resistor color codes are worn but on mine I think R13 is 750 ohm
I'll post some pics soon. Its partially disassembled at the moment
Heikki
« Reply #4 on: March 01, 2021, 01:01:30 AM »
Audio signal and control voltage are brought to different grids. That's something you don't see in old broadcast limiters but probably works well enough in a speech limiter. To avoid overloading the gain reduction stage in broadcast limiters the control voltage goes to remote-cutoff and sharp-cutoff grids and audio signal goes only to the remote-cutoff grid. Here it seems audio goes to remote-cutoff grid and control voltage to sharp-cutoff grid.
I like that C2 is used to keep DC current away from T2 primary. 10k primary being fed from a very high source impedance doesn't look great and speech limiter might not have transformers with great frequency response to begin with.
The original schematic has very slow attack time. In the modified version attack has been made faster.
Before spending too much time and money I would probably check if the unit has decent enough frequency response for modern use.
« Reply #5 on: March 01, 2021, 01:41:00 AM »
Pics I have of one of these have a date of manufacture of 5/44. Mix of transformer types, some nice Thordarsons on there.
The 1st version 57-D from the late 1930's was advertised as a compressor for radio stations.  I've found most things of that era pass pretty modern sounding audio, in regards to bandwidth.
abbey road d enfer
« Reply #6 on: March 02, 2021, 04:56:23 AM »
I believe it's the opposite. According to datasheet, pin 5 is the remote cut-off grid and pin 8 the sharp cut-off. Which makes sense. Anyway, the paucity of information regarding the construction of 6SA7 makes it subject to conjecture...
Heikki
« Reply #7 on: March 02, 2021, 05:46:26 AM »
From RDH3:
The 6SA7 is somewhat similar in construction to the 6L7-G but No. 3 grid has a super control characteristic whereas in the 6L7-G the first grid has a super control characteristic.
« Reply #8 on: March 02, 2021, 08:26:04 AM »
That is an odd hack.   Seems you'd want to take the output off the 6V6 plates with a blocking cap to get the faster attack times.  You wouldn't need the xtra gain stage in the side chain if done that way.
I'd be weary of that OT being able to take a pair of 6V6s without distorting.  Probably why they put the dual 500K pots there.  You can just rebuild it as a permanent voltage divider with fixed resistor values set for keeping output at a proper level.  Make sure the PT will take the xtra current draw if you rebias.
All this said without consideration of what happens upstream.  Maybe they just wanted higher headroom or more driving power in the output stage.
« Reply #9 on: March 02, 2021, 02:59:47 PM »
I'll post some pictures later this week.
It seems that the unit I have might actually pre-date the schematic/manual I've been referencing.  Pot code on the dual 500k suggests 7th week of 1946 and the manual is dated 1952.
Both potentiometers are slotted type and mounted on the back of the chassis (i.e. set and forget).
I was tempted to do what lassoharp suggests and wire a fixed setting in place of the output pot and put a level control before the feed to the sidechain.  Level / threshold would then be interactive
« Reply #10 on: March 02, 2021, 03:03:36 PM »
Also, I found an eBay listing for a similar unit sold a few years back
https://www.worthpoint.com/worthopedia/wilcox-electric-co-tube-compressor-1886161028
This one is Wilcox model 57DE, looks the same as mine excepting the tube complement and the silver spray paint
« Reply #11 on: March 02, 2021, 03:12:26 PM »
That's a funny repaint, from the era when rust killed sales.  It doesn't anymore.
here's the 1944 unit.
I've never had one, saw several in person side by side once.  I remember missing one on ebay for $1 once.....
« Last Edit: March 02, 2021, 03:32:05 PM by EmRR »
« Reply #12 on: March 02, 2021, 04:23:07 PM »
Interesting, Emrr, the one you posted looks like it has 4 pots.  I see one in between the 6H6 & 6SN7 as well as the one by the i/o connectors that mine doesn't have.
« Reply #14 on: March 30, 2021, 09:41:56 PM »
I've had some time to work on this.
The power transformer had some shorts so I put in a replacement Hammond 273BX - running that at least for now on the 125V taps.
I made some frequency response measurements of the transformers in the audio path-
T1 input:
https://drive.google.com/file/d/1EWNlgxJWFVYcdsyseKa3RxIA2O8TlfcZ/view?usp=sharing
T2 interstage:
https://drive.google.com/file/d/1n9tPqU_tQ1bfHN8wGhNT6NWYw_mM6Rmd/view?usp=sharing
T3 output:
https://drive.google.com/file/d/1q4ch5QINLVn7Ndpl7UarWacH1wY5lCfi/view?usp=sharing
Other than replacing the PT I also swapped out the electrolytic and mica caps and I replaced the dual 500k pot with two 470K resistors (one per tube I mean).  I have a pair of Shallco 600:600 variable T pads, I've been testing with one on the input and one on the output.
Here is a measurement of the response of the limiter with the input T pad fully cw (has loss of about -5db) & the output T pad sitting at 9 o clock.  There is some heavy limiting action going on here.
https://drive.google.com/file/d/18lWBZg5wuM5q-sPOIlKevK8vSTY7KmFR/view?usp=sharing
R16 (100K pot) adjusts the threshold of limiting - it seems like the ratio also increases as I lower the threshold?
I was hoping someone could give me some tips for adding a db reduction meter.  I have a spare 1ma meter that I could use but I'm not sure where to wire it in.  I don't have much of a grasp on how the 6SA7 tubes work.
So far I've just been working with test signals but I might experiment with this after I get a little further and have a chance to run some program material through it.
« Reply #15 on: March 30, 2021, 10:05:23 PM »
Oops..should be good now?
« Reply #16 on: March 31, 2021, 12:34:52 AM »
The typical place for a meter is in series with R2.  Look at all the other tube limiters in tech docs.  It may or may not need a parallel resistor to set the range.
« Reply #17 on: March 31, 2021, 10:40:17 PM »
I've looked at GE BA9, Sta Level, Altec 436, etc
I've got the 1ma meter in series with R2 to ground and a 5k resistor strapped across the meter in parallel.  The 5k meter is helping to zero it but the scale is narrow.  I'm measuring something like 20db gain reduction and the meter isn't moving all that much.
I tried a Sta Level type meter circuit as well with the same result
Gates SA-38 uses 1612/6L7 a similar tube to the 6SA7's.  I thought maybe I'd try wiring in a meter and resistor in parallel at the junction of R5/R7 & R6
abbey road d enfer
« Reply #18 on: April 01, 2021, 01:10:40 AM »
The problem there is that R4 & R3 inject much more current (about 10mA) than the actual cathode current, which results in teh obervation that the needle hardly moves.
abbey road d enfer
« Reply #19 on: April 01, 2021, 01:12:21 AM »
That would certainly provide a more sensible indication.
Last post May 24, 2016, 11:16:48 AM
by mjrippe
Last post August 10, 2019, 08:23:01 PM
by opacheco
Last post January 01, 2020, 01:45:32 PM
by GYM
Last post June 30, 2010, 07:39:27 PM
by Biasrocks
