abbey road d enfer
Re: Wilcox M57D1 tube limiter restoration
« Reply #20 on: April 01, 2021, 06:24:02 AM »
From RDH3: The 6SA7 is somewhat similar in construction to the 6L7-G but No. 3 grid has a super control characteristic whereas in the 6L7-G the first grid has a super control characteristic.
Weird. According to datasheet, G3 is the RF input; I wonder why signal should go to an input that has less linear transconductance...  ???
Heikki
« Reply #21 on: April 01, 2021, 06:59:53 AM »
That seems to be the way it was usually done in compressors and expanders.
https://worldradiohistory.com/hd2/IDX-Site-Early-Radio/Archive-Radio-Engineering-IDX/IDX/35/Radio-Engineering-1935-12-OCR-Page-0026.pdf
abbey road d enfer
« Reply #22 on: April 01, 2021, 01:43:40 PM »
Well, since there is no technical justification for this choice, I have to take it at face value.
I still feel it strange, particularly considering it's a feed-forward arrangement.
« Reply #23 on: April 10, 2021, 11:57:05 PM »
I've had a little more time to work on this...
200uA meter is working well strapped across a 220 resistor at the junction of R5 & R6/R7
I moved the sidechain signal tap to the 6V6 plates - each side through a 220K resistor & .047uf cap.  Otherwise the amp was getting too distorted before I could get the threshold into a useful range.
Next I will replace the carbon comps with metal film and then fine tune a bit more
It sounds pretty good
abbey road d enfer
« Reply #24 on: April 11, 2021, 12:15:49 AM »
Not surprizing since you had one less stage in the side-chain after your mod.
Don't throw them away. Put them on ebay. They're full of mojo.  8)
« Reply #25 on: April 11, 2021, 11:33:48 AM »
Not really of consequence, but I'm not sure this was modified before I got it - I could be wrong but the wiring all looked original.  Perhaps an earlier revision because the date codes pre-date the schematic I'm working from by about 8 years
« Reply #26 on: April 11, 2021, 12:04:01 PM »
When I inject sub 60hz signal into the unit I'm getting some motorboating that occurs only while limiting.  I didn't notice this when the sidechain was fed from the 6SN7.  Increasing C6 helps somewhat but it doesn't entirely disappear.  I haven't tried increasing C1 yet.
Before fine tuning I will wait to replace resistors and try to make sure the input tubes balance is OK - In particular, the anode resistor to V1 (R6) has really drifted in value.  I thought of also adding a balance trimpot on the cathodes of V1/V2.
abbey road d enfer
« Reply #27 on: April 11, 2021, 01:48:36 PM »
  My understanding of your first posts, you took one 12BH7 and put a 6V6 instead...?
« Reply #28 on: April 11, 2021, 02:06:28 PM »
No, I redrew the circuit as it was when I got the unit.  The Army manual I have is from 1952 but the pot codes are 1946. It seems possible I have an earlier version with a pair of 6V6 on the output rather than a 6SN7 and minus the 6SN7 side chain gain stage
abbey road d enfer
« Reply #29 on: April 12, 2021, 11:54:19 AM »
OK, got it.
Last post May 24, 2016, 11:16:48 AM
by mjrippe
Last post August 10, 2019, 08:23:01 PM
by opacheco
Last post January 01, 2020, 01:45:32 PM
by GYM
Last post June 30, 2010, 07:39:27 PM
by Biasrocks
