valco
Binson and Korg stage echo in patch
« on: March 06, 2021, 08:42:09 AM »
Hi !
I'm trying to figure out how to get my binson echorec 2 and korg stage echo to work as outboard reverbs in my patch. Does anyone have any experience with this and got any advice? Is reamp box the best solution ?
Whoops
Re: Binson and Korg stage echo in patch
« Reply #1 on: March 06, 2021, 10:23:40 PM »
Hi !
I think you mean outboard Delays and not reverbs since both those units are Delay units.
I use those type of units, and other tape delays all the time in mixing.
I don't find the need for a reamp box but I'm carefull to not send a lot of level into it, so I lower the Send output fader to -16 or -20, I just send more signal into those units if for some reason I want to distort their inputs.
What setup do you have?
Are you connecting them to an analog console or to an Audio Interface (soundcard)?
valco
« Reply #2 on: March 09, 2021, 10:20:43 AM »
Well yeah they are delays, but the stage echo is also a reverb. So what I meant is, how to use them as outboard effects.
It's the signal I am trying to cope with. If I should build some reamp boxes with transformers to get the right level into the effects or not?
I am using an Antelope orion with a patchbay
Whoops
« Reply #3 on: March 09, 2021, 10:33:07 AM »
Hi Valco,
no reamp needed, line output from Antelope to unit input, output fader from the DAW at -20 or -16.
output from the unit to a line input on the Antelope
Thats it, have fun
« Last Edit: March 10, 2021, 05:21:18 PM by Whoops »
abbey road d enfer
« Reply #4 on: March 10, 2021, 04:26:00 AM »
As much as the Stage Echo can drive low impedances (opamp output), the Echorec is lacking in this domain. TheECC83 running at ca. 1mA starts to struggle in a 10k load and the -3dB point is at 100Hz, which is not an issue for guitar, though.
I would add a buffer or DI box.
valco
« Reply #5 on: April 09, 2021, 02:51:35 PM »
I think Russell Elevados chain in this video answers my question. https://www.youtube.com/watch?v=DB6kGF13hxA
He goes out from daw > reamp box> Echoplex >DI > preamp
Whoops
« Reply #6 on: April 09, 2021, 10:12:54 PM »
Me and Abbey answered your question
Last post December 30, 2005, 08:22:09 PM
by PRR
Last post August 17, 2019, 05:47:33 AM
by krazh
Last post April 01, 2012, 03:55:41 AM
by Seditionary
Last post October 13, 2018, 04:33:08 AM
by masteringpole
