Never, Ian! I was confused by the drawing as well and thrown off by the handwritten numbers by the XLR pinout.
Question to the O/P: Is there enough room inside the PSU to fit a submini tube and a shielded transformer? It seems to me the extra cable and box could be eliminated.
Thats a good idea about eliminating the box. The PSU is for 2 mics and its pretty full aready. A submini tube and 3 resistors per channel is about all I could fit.
My apologies everyone, this is a bit sloppy. I was really hoping for a free lunch.
I appreciate all the input.
I turned your ideas for the next version into a proper schematic and will lay it out the PCB and release the gerbers in gratitude when we get it finalized.
That aside, Im a few resistors away from a textbook cathode follower circuit.
Inside the PSU, there is 39k from cathode to ground. From what I can tell, Im just missing 1 resistor, and I've misplaced 1 resistor
In the article this PSU was built from, David Royer shows a more typical common cathode arrangement, and then suggests you build his stripped down version for his particular application.
https://web.archive.org/web/20090901000000/http://www.diyfactory.com/projects/royerproject/royermod_2.pdfIt seems like he is taking advantage of a corner case thats too advanced for me.
Back to a typical common cathode. Rg, needs to connect to the the 39k Rk that is inside the PSU.
Additionally, I need R bias between that node and the cathode. Is 1k a fine starting point?
I've attached a revised version that looks alot like the c60 schematic now.
Gus, I have plenty of clean options, so Id prefer something with gain and some output attenuation. I haven’t found a load line calculator for these tubes, so I can’t fake my way through this one. In any case, gain would require another stage, or a common cathode configuration, right?
Should I just try the 1k bias resistor and leave the 4M4 Rg and 39k Rk?
B+is 95 loaded.
If I understand cathode followers correctly, the output signal will be roughly the same amplitude as the input, but lower impedance and reverse polarity, and no change in resistor values will give me gain of more than 1.
Thanks for your patience!
Chris
