Hello, everyone,
I am looking to see if anyone here has an Allen and Heath ZED12FX that they wouldn't mind taking the underneath panel off and taking a pic of where the brown cable connects to the effects daughter PCB that sits on the channel boards. I have been modding/upgrading mine for fun (1000uF coupling caps, TLE2072A, fader make up amp adjust, etc) and somehow I wasn't paying attention when I resoldered the lead that provides voltage for the effects board and connected it to ground. It burned out the 10R resistor and blew a cap, which did what it was supposed to do. After I replaced those parts and connected it properly, it makes this snapping noise, like a clocking issue, but it is also has the effect following it. This tells me the effects part is working but there is a something else in the digital realm on that board that is not happy or was damaged. I have a replacement board coming but I wanted to double check what the connection should before I rewire it.
Paul
