Hello, everyone,
I am redoing my pedal board in hopes that cleaning it up and better organizing the layout that I will be more inspired to actually use it for recording instead of having it sit in storage. One of the things I want to sort out is to make a small enclosure with a 9VAC and 12VAC output to power a Whammy and a Hughes and Kettner Tubeman, both which require AC inputs. Finding a 115V - 12VAC transformer is pretty easy but locating a compact 9VAC that will do 2A is a bit harder to find. Some options are:
1 - Use a 18VAC transformer and wire the primaries for 230V, halving the secondary voltage (US power)
2 - Get another 12V and attenuate voltage on the secondaries to 9V
Now the Whammy has a regulated VDC supply using 7805/7905 regulators, which I'm sure are the fixed version and the spec sheet says that they have a max DC input of 35V, so I should just be able to use another 12V and not worry about it. But if I were to proceed with one of the two options, the questions that arose are if go with number 1, will the VA rating stay the same on the secondaries and if I choose number two, can the secondary voltage be adjust with just a potentiometer and a fixed resistor to prevent shorting them together?
Paul
