what was the different between the v72S and the v72?
6dB of additional gain with the V72S. Two ways that I've seen this done:
Units built that way by Siemens & Halske replaced the 80K feedback resistor with 165K and a correspondingly lower value parallel capacitor.
Earlier units modified by E.M.I. split the first valve cathode resistor in two (the 1K25 became a 680R & 560R) and then both feedback points were taken to/from the mid point.
Oliver Archut had details that indicate the Siemens units had a mechanically different input transformer.
Earlier E.M.I. units I saw had the standard V72 input transformer.
I've seen two or three different IPT secondary termination resistors too, depending on batch/vintage.
But all in all, quite small differences really.
Edit: A small detail I forgot: some of the amps in the desk (echo send etc.) utilized the V72's built in bass filter that was engaged by leaving the tuchel connector pins 2a & 2b open which puts an internal 1uF cap in the middle of the input transformer windings. However, an additional .25uF was wired across pins 2a & 2b which is then, of course, in parallel with that internal 1uF.
The now 1.25uF value gives a slightly lower frequency of bass cut off.
