Hi, I hate to beat a dead horse, but I've been circling back to some of my early interests before I knew anything about electronics - I've been putting together a Helios Mic Pre, wanted to share what's working for me, and ask for some suggestions - everything I've been able to find on the forum so far either uses the 2128 pre into an EQ (Rocinante and ruffrecords have been massive sources of inspiration), or uses the 22113 output card as the preamp (which apparently doesn't sound half bad, once again, thanks Rocinante!)
I've been trying to integrate the two cards into one simple preamp, but hit a bit of a hiccup - my current schematic is this (R33 and R20 are both 5k revlog pots to control gain):
It simulates well, with one problem - there's way too much gain. Following the wise recommendations of my predecessors, I'm aware pushing the 2128 (first half of schematic) past 40dB isn't a great idea, which is why R34 is there (to act as a limit on the gain) but even cranked down to the minimum, I'm getting 20dB of gain after the 2128 stage, and 36dB gain after the 22113 - I'm planning on adding a 15dB pad at the start, which will offset the gain from the 2128, and I could always add a bypass switch on the output stage before the output transformer, but I'm a little concerned that the 2128 doesn't have enough juice to drive a 600ohm load...
Just to clarify, R14 is where the 2128 stage goes into the 22113 stage...
Any thoughts would be appreciated!
