Shure sm81 troubleshooting
« on: March 30, 2021, 10:29:17 AM »
Hi, I got a second hand sm81 mic which I'm think have a problem of not enough high frequencies. Here's a comparison of the sm81 to a sm58 on acoustic guitar. Are you agree with me that the 81 is faulty?
And if so, there's a way to determine if the problem is in the capsule or in the mic circuit?
sm81 sound clip:
https://drive.google.com/file/d/1SFf2ROJC1WfNO6aPS4jqLxmjaqZVYqrv/view?usp=sharing
sm58 sound clip:
https://drive.google.com/file/d/1AS2mjv8i8_Us1Yb9C-jfKjymjSLMiFYJ/view?usp=sharing
rackmonkey
Re: Shure sm81 troubleshooting
« Reply #1 on: April 02, 2021, 01:09:16 PM »
I don’t agree with your assertion that there’s something wrong with your 81. The SM-81 is known for having a flat response up to 20kHz. You’re comparing it with an SM-58, which has a significant presence lift for vocal intelligibility. Apples to oranges. Sounds 81-ish to me.
If you’re used to mics with a boosted high end (like very many dynamics and inexpensive modern condensers have), it’s possible that flat response mics might sound dark to you.
« Last Edit: April 04, 2021, 03:08:52 AM by rackmonkey »
Whether you think you can or you think you can't, you're probably right.
« Reply #2 on: April 03, 2021, 08:58:57 AM »
If you’re used to mics with a hyped high end (like very many dynamics and inexpensive modern condensers have), it’s possible that flat response mics might sound dark to you.
Thanks, you're right, I used to work with AKG 451 with ck1 capsule as a pencil  condenser which have very bright sound with a lot of high frequencies.
But yes, it seems like my sm81 is working as it should  :D .
Whoops
« Reply #3 on: April 04, 2021, 10:11:23 PM »
Sounds good the SM81 to me,
it has more bottom than the SM58, seems to not have the High mids boost and has more info above 12khz.
So it seems right comparing to an SM58.
But if you have doubts the best thing would be to get another SM81 from someone and A/B them.
Last post August 17, 2004, 03:34:39 AM
by microx
Last post September 02, 2004, 01:59:06 AM
by BYacey
Last post March 11, 2006, 08:31:55 PM
by jetboatguy
Last post November 04, 2007, 04:12:02 PM
by gary o
