thomasdf
Urei 809 speaker filter refurbishing : old caps value
« on: April 04, 2021, 12:04:51 PM »
Hello
I am lucky guy : I was given a pair of Urei 809 speakers. The drivers are working, but need refoam. I decided to recone them in order to take a fresh start.
I was also planning to change the electrolytics in the filters but they have old values that are hard to find today :
75uF 100V x2
20uF 100V
4uF 100V
My question is : where can I source these ? Sprague Atoms have these values but I can't find the 75uF 100V (Sprague Atoms is 75uF 16V).
Can I use non polarized capacitors or lower the max voltage (I'd prefer not) ? I am total noob when it comes to filters..
I am posting the schematics here for those of you interested.
Thanks in advance
Thomas
« Last Edit: April 04, 2021, 12:19:51 PM by thomasdf »
jensenmann
Re: Urei 809 speaker filter refurbishing : old caps value
« Reply #1 on: April 04, 2021, 12:23:01 PM »
You could replace electrolytics with polypropylene caps. These are available in a huge variety of values since they are used for electric motors. Not cheap, though. Some may think it´s overkill ;-) Check the bigger parts suppliers like RS or Mouser, e.g. https://de.rs-online.com/web/c/passive-bauelemente/kondensatoren/polypropylen-folienkondensator/?applied-dimensions=4291708970
Visaton offers (besides polypropylene) a variety of bipolar electrolytics for crossovers: https://www.visaton.de/en/products/accessories/crossover-parts/electrolytic-capacitors
Since speakers have huge tolerances, even more if aged, I´d not overthink a certain amount of tolerance in your new parts. Buy what gets you closest. Many manufacturers use paralleled caps to get the values needed, btw.
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
« Reply #2 on: April 04, 2021, 12:39:12 PM »
What ^ said.  Going to film caps will be an improvement.
thomasdf
« Reply #3 on: April 04, 2021, 01:18:22 PM »
Hello, thanks for your answers. Polypropylene seems a bit overkill for my budget indeed, at least for the moment.
I'll check out film caps as well as visaton's bipolar caps.
« Reply #4 on: April 04, 2021, 01:48:51 PM »
Here in the US Dayton Audio has very affordable film caps for speakers.  Must be something over there.
https://www.daytonaudio.com/category/36/capacitors
thomasdf
« Reply #5 on: April 04, 2021, 02:40:55 PM »
Thanks Doug, I'll check this out :)
Here in Europe I have found F+T Bipolar Capacitors. They are electrolytics, but super cheap (most expensive I need is 1,74 euro at Banzai) and said to be good quality. If I go that route I'll use 4.7uF instead of 4, 22uF instead of 20, and 68uF+6.8uF in parallel giving me 74.8uF for 75uF.
Since the speaker used electrolytics originally I guess it's not THAT bad, so I have this safe and cheap option.
I can easily source Mundorf too, electrolytics bipolar and film also (tho they get quite expensive!!)
After some research, I think I'll go with Jantzen Audio film caps (3.9uF and 20uF) and Mundorf electrolytic bipolar parallel 68uF / 6.8uF. That's the most cost effective solution I have found.
I'll let you know what it sounds like !
radardoug
« Reply #6 on: April 04, 2021, 04:36:54 PM »
So you got the speakers for free, and now you are quibbling about spending money on good caps for the crossovers???
« Reply #7 on: April 04, 2021, 07:15:16 PM »
Make that 6.8 a film!
Khron
« Reply #8 on: April 04, 2021, 07:26:47 PM »
Motor run caps should be polypropylene most of the times, and available for a handful of bucks a piece (?)...
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
jensenmann
Jens
Quote from: PRR
abbey road d enfer
« Reply #10 on: April 05, 2021, 05:05:08 AM »
They look tempting. However I would consider the implications of their warnings:
"Rated Voltage:See Rating Tables.  Rating is the 50/60Hz RMS voltage for a sinusoidal waveform.
maximumFrequency:50/60 Hz. For higher frequencies use General Purpose AC Capacitor Series."
(from the RS datasheets)
So far I haven't seen an explanation of these warnings.
Khron
« Reply #11 on: April 05, 2021, 06:06:41 AM »
They're usually rated for mains voltages (250-400V AC). Sure, that might need derating for higher frequencies (like oscilloscope probes), but if you're expecting over 100V AC (!!!) in your passive (!!!) crossover, maybe that's a good reason to consider going active?
thomasdf
« Reply #12 on: April 05, 2021, 06:33:34 AM »
What I've seen is more between 30 to 80 euros for ONE capacitor.
And it's not because I've been given a pair of speaker that I am rich, and that I have that much money to spend on capacitors.
thomasdf
« Reply #13 on: April 05, 2021, 06:35:43 AM »
Will do ! I was wondering if its ok to mix caps type. Thanks !
Khron
« Reply #14 on: April 05, 2021, 08:36:49 AM »
Yeah, no idea where you've been looking, but...
https://www.tme.eu/fi/en/katalog/motor-capacitors_100263/?s_field=1000014&s_order=asc&limit=20&currency=EUR&page=1
thomasdf
« Reply #15 on: April 05, 2021, 10:04:53 AM »
I'm looking at audio caps, mainly.
Motor caps at RS and Farnell are crazy expensive too... at least in France ?
On the Urei 809 the crossover slide out of the speaker and have some room for the caps, but I'm not sure motor caps would fit, they are quite big.
I just ordered Jantzen Audio film caps, except for the 68uF value I went with Mundorf bipolar. 50 euros worth for both speaker. It's a good start to see how they sound.
Thanks everyone for your help
Khron
« Reply #16 on: April 05, 2021, 10:07:29 AM »
TME deliver all over Europe / the world too, but if "audio caps" make you feel better... ::)
mg73
« Reply #17 on: April 05, 2021, 02:29:51 PM »
Please let us know how this  sounds.
I have a pair of 809 I would like to upgrade.
thomasdf
« Reply #18 on: April 05, 2021, 02:54:18 PM »
I will :)
abbey road d enfer
« Reply #19 on: April 08, 2021, 12:56:44 AM »
I'm not concerned with voltage. I'm concerned with the fact they don't recommand these caps for passing higher frequencies, which is something that's bound to happen in a passive x-over. They don't give any hint on what could happen if...
Last post January 24, 2006, 03:44:19 AM
by pucho812
Last post July 05, 2006, 06:43:23 PM
by ciminosound
Last post October 18, 2010, 09:54:48 AM
by johnR
Last post July 27, 2020, 11:50:00 AM
by Studiogearlover
