12V or +/-12V? It makes a huge difference.
Most circuits that are designed for +/-15 are happy with +/-12, with only a couple of dB less headroom.
Single +12 requires an optimized topology where transistor Vcesat does not tax headroom unduly.
Many circuits designed for +24 can be modded for +12, but the headroom limitation will still be there.
Now you can do worse than checking Nagra schematics.
Thank you for your answer!
Yes, 12v VS +/-12v is totally different. I just meant, throw anything at me. Since Eurorack PSU can can deliver either one rail of 12v or dual +/-12v I am interested in any known circuits that are considered "good" to work on eiter single or dual.
RE modding a +24v design into +12v. It would be truly amazing to learn how to do mod a 12v version of the Helios 2134 circuit that I am currently playing around with. or why not a BA283 for that matter.
Perhaps this requires a thread of it´s own, depending on how complex this is?
Is it a matter of changing/adding a few components or is a much more complex road to enter?
With my 0% knowledge I immediately start to wonder: Is there not a way to take advantage of the -12v rail, even though its a single + rail design. Perhaps convert that to bump up the voltage of the +12v single rail somehow?
oh, shut up.. I shouldnt be guessing things I do not know of.
Thank you for taking your time.
//Ted
