Neve BA440 with 2520 pinout
TillM
Berlin - Germany
Hi Guys,
I was thinking about convert the BA440 to 2520 pinout.
But now I’ve some questions.
The BA440 works with 24v.
Is it possible to drive them with 16v?
Which components I have to look at?
Second question.
The 441 and 461 and really big transistors. I’m sure, I’ve to substitute them.
Any help is really appreciated.
Best
Till
TillM said:
Hi Guys,
Yes, understanding that headroom will decrease sihnificantly.
You may have to adjust R1 slightly, for symmetric clipping.
Second question.
In the decades that have passed since the days this circuit has been designed, transistors have evolved considerably. However you must take into account that there is not overcurrent protection apart from the 1.5r emitter resistors.
ZTX651/751 are good candidates.
Do you really need or aim to run it at 16V?  Or did you mean + & - 16V as is usual with the 2520?
With the BA340/BA440, in order to achieve decent headroom in the desks using a 24V single sided supply, the amp was usually run into a transformer with a primary strapped for 50 or 75 ohms, and the usual secondary Z of 600 ohms.
This means that if you like to cook your signals on the hot side of things, the amp is running class B a lot of the time.
Nothing at all wrong with that, just pointing it out.
Yes I mean for +/- 16v.
My idea was to use it as a OP Amp in my API style preamps or for the Hairball Lola.
Problem is, that I’ve to learn a lot about electronics in this case.
So I need a lot of help to realize it.
The BA440, like most of the vintage Neve designs, does not have true differential inputs. The input impedance of the inverting input is much lower than that of the non-inverting. It makes it unsuitable for most EQ's and requires adaptation for other stages.
The main issue being the output offset that is not stable and requires individual adjustment.
Abbey nailed it.
If you keep in mind everything he said and tailor your surrounding stuff accordingly, then it's certainly possible to use it as you want.
For a Neve amplifier that's much more 'plug-and-play' in an API type environment, you could look at the BBC designed BA512 which has a more typical 3 stage 1/diff-amp input, 2/transconductance amp, 3/low Z output stage topology
The BA 512 is neat in that it was a little ahead of its time and had two pole compensation, although the stock miller cap might be a little too severe for higher gain applications.
Edit: corrected mistake with amp number.
Winston O'Boogie said:
For a Neve amplifier that's much more 'plug-and-play' in an API type environment, you could look at the BBC designed BA540 which has a more typical 3 stage 1/diff-amp input, 2/transconductance amp, 3/low Z output stage topology
The BA 540 is neat in that it was a little ahead of its time and had two pole compensation, although the stock miller cap might be a little too severe for higher gain applications.
Hi Winston, a quick google did not bring up anything at all for the BA540.  Do you have a schematic you could post?
That's because I'm an idiot  :-[
I wrote the wrong number, I meant BA512 not 540.  Sorry!.
The details are attached:
  • BA512 Output Op Amp.pdf
C3 & C4 at 1nF each, together with R12 of 1K are the two pole compensation scheme.  The effective dominant pole miller cap value would be the series value of these two, so 500pF.
This gives enough stability for a closed loop gain down to about 10dB.
If you wanted/needed a closed loop gain that was somewhat higher, then you could lower the values of the caps.  As a practical example, I used values of 470pF each (235pF series value) for a closed loop gain of approx 24dB and the circuit was quite stable.
An easy rule of thumb I use for checking stability is a margin of 12dB, so if you can lower the gain by 12dB less than you want without instability or seeing anything strange happening on your 'scope, you're OK.  It's worked for me anyway.
Of course, you could just leave things as they are regardless of the gain you want, but there are benefits in terms of having more feedback at higher frequencies when using the lowest practical values there.
mjrippe said:
Thanks, Winston.  I do have a schematic for the 512 but as always, your insight and explanation are invaluable.
Cheers dude.  Sorry again about sending you off on a wee goose chase  :)
Personally I'd keep it at +24v but like you I played around with the 2520 footprint as it was easy to recall in Eagle. In the end I just went the ba338 ba340 route. The ba340 transistors gets hot. They need heat sinks at the output. You'll see a bunch of aluminum hats in early designs. I played with them for a 33115 (I might have that designation wrong) mic preamp. It's what they used in the 1081 pre/eq, albeit with transformers, inductors and such. The components for between the stages has troubled me as I've read several variations.
Eventually they settled on the 440 which used op amps (please correct me if I am wrong).
Nevertheless the ba338 and 340 was a hardy amp section and with the right transformers sounded warm although a bit of noise (which I ascribe to my own poor abilities)
Several folks though have made great clones.
I'd actually love to know the actual components between the ba338 and ba340 stages. And or the ones before and after.
Ok, a little clarification about Neve amps:
338 - amp board used in preamp and eq of 1081, 3104, etc.  Discrete 5 transistor.
340 - output amp, as above.  Discrete 8 transistor.
438 - amp board used in pre and eq of 33114, 33115, etc.  Discrete 5 transistor.
440 - output amp, as above.  Discrete 8 transistor.
638 - amp board also used in pre and eq of 33114, 33115, etc.  5534 IC
640 - output amp, as above.  5534 IC plus 2 transistors.
All of these run on +24VDC.  The BBC spec'ed the 5534 boards because of their faster recovery from overload.  The studio I tech has 40+ 33114 modules and nobody can tell which have 4xx series and which have 6xx.
EDIT: Schematics of all 6 attached.
  • Neve Amps.pdf
