I have recently moved into a new house. Today I have set up my guitar rig and have been experiencing weird noise problems, pops and clicks and various degrees of hum/buzz as I touched the guitar metal parts, or any other ground in the room.
Initially I mistakenly thought there was something wrong with the grounding in the guitar, the amp or the house itself.
But then I tried using an ESD wrist band and the noise drastically improved, and if I grounded myself directly touching one of the radiators pipes it completely disappeared.
I guess the problem lies in the thick carpeted floor so there's a buildup of static that in turns gets transmitted to the guitar through my body.
I am trying to figure out what are the possible solutions to this problem, and the only viable option seems to be one of those anti static rubber mats like they use in the electronics manufacturing industry.
I have also read about anti static spray products but I guess that would be just a temporary fix...
Was wondering if there is an alternative solution ?
I am also starting to suspect whether this issue has been the cause of other problems...
I had initially setup my daw system with a TC Electronic firewire audio interface and I could not use that because of noise problems, I had random pops and clicking noises in the audio that did not appear to be related to buffer size etc. none of the internal settings solved the problem.
I tried the other interface I have an RME Fireface and that worked without problems.
Then a few days later one of my Neumann monitors died with a failure in the switching power supply.
Is it possible the static generated noise problems in the firewire interface and even blew up the monitor or that's just me being paranoid ?
Perhaps it's my brain that's ESD and after all this static I am starting to imagine things that aren't there ?
I have been reading on some hi-fi forum about spacing speaker cables away from carpeted floors as the static can affect the sound. I cannot tell if this is pure audiophoolery or actually there is some truth to it.
