cathodes are at +160 volts relative to ground. So, I have to bias the heater up to +115V. So cathode should be aprox 45v above heater.
What I want to know is what do you think is better for using as the +115v reference point in the heater PSU.
Should I leave all pin 9 on the tubes unconnected and use the +12v return as a 115v reference (as n the 1st drawing), OR should I use Pin 9 at one of the tubes as the reference point instead (as in the 2nd drawing)?
Sorry for the bad representation of heaters. I couldn´t find a better way unfortunetly. Anyway, each arrow is a set of heaters in a 12au7 tube, with two heaters and three pins (4,9,5). I hope it´s understandable.
