loading down api312 outputs
Jonkan
Sweden
I read this over at gearslutz:
Originally Posted by Flora
I recently got a pair of the API 512c's. I love the way they sound but even with the pad on the signal is often too hot even on sources of very moderate volume. I have 2 more spaces in my API rack and I need a couple more mic pres - so my question is: would the BAE 312s (which Ive heard so many great things about) be better in this respect or do they have the exact same issue?.
and the answer:
On the API gear in the racks you have to load down the ouput.
Its part of the reason they sound differently than in the board(more mid forward).
I think API recommends a 600ohm resistor, but i've gotten a closer sound to the board with a 1200ohm resistor on the output
So, having built some api312 channels..is this something that i ought to do to my pres to get the most out of them? Can anyone explain to me why (or why not) i should do this?
I talked to tekay about this some time ago and he measured up the freq response using a profile 4048 transformer and a 600ohm resistor, and it was the same as without one if i remember correctly. But the signal output level got a bit lower. So maybe i dont really need to try this?
But seeing someone else recommend it got me interested.
any thoughts?
/Jonas
Between which pins on the xlr out do i so
the resistor would go between pins 2 and 3 on the XLR. Im not mr. smartstuff or anything, but I dont think thats the problem. The 512C uses a big step up transformer on the input which is waaaay different than the older modules which uses a lower ratio. I havent screwed with loading the output but the differences between these has always seemed to be the input for me.
dave
