> Would be interesting to know who exactly was meant.
"Everybody". That first figure has to be the most common FET limiter on the planet. (Tho IIRC, the LevelLock doesn't bother with the distortion cancellation....)
> ESP-hint didn't seem to be towards Phil A,
The second, improved, version mentions a "Phil", and Phil A is a possibility. I had not seen that exact scheme, but similar themes are pretty common.
> a good ref for FET use as voltage-controlled R's is in Designing with Field-Effect Transistors, second edition, revised by Ex Oxner, McGraw-Hill, 1990.
From http://abe.com I find two books of that name:
Designing With Field-Effect Transistors (ISBN:0070574499)
Siliconix Incorporated; Evans, Arthur D.
McGraw-Hill. 1981.
Price: US $14.00-$40.00
Designing With Field-Effect Transistors (ISBN:0070575371)
Incorporated Siliconix
1/10/1989 McGraw-Hill Companies.
Price: US$ 29.95
Designing With Field-Effect Transistors. Second Edition (ISBN:0070575371)
Oxner, Ed
Book Description: McGraw-Hill 1990.
US$ 120.00
Sadly for everybody but me, I just ordered the $30 copy dated 1989. I assume this is the same as your 1990 citation. The ISBN is the same as the 1990 $120 copy, so it should be......
