thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
Experienced engineers may choose to skip the following information, I?m posting it here for newbie diy-ers that it may be useful to.
On the old message board I made a couple of posts relating to positioning mains toroids for least hum; true to nature I managed to disregard my own advice in the last few days...
A friend asked me to evaluate and comment on a prototype stereo preamp that had been sitting on the shelf for a while. As with many prototypes, the casework was quite rough and ready. Upon listening to the unit I found that it sounded superb, but had a frustratingly loud hum. With it being a prototype I suspected the grounding-scheme. Spent days re-jigging the ground scheme - bleeping all connector bodies, minimising cable lengths to the star-ground, moving the star point around the ground-plane, experimenting with local grounds as well as the star-ground etc etc, but to no avail.
After much head scratching I decided upon the obvious tactic of loosening the bolt in the mains toroid and rotating the body, thinking this would just be too easy if it solved the problem... Turns out that the whole problem was inductive hum introduced by the field of the toroid! Weirdly, I found that the best position for the toroid was with the cable outlet facing the preamp board, and moving it in one direction introduced the hum on one channel but not other, and vice-versa if rotated the other way. Eventually I found the quietest way was to turn the toroid upside down with the wires facing the pcb (I used a 10mm thick rubber washer I had lying around to prevent the leads being squashed against the chassis).
The moral of the story? Whenever you build anything using a toroidal mains transformer, ALWAYS loosen off the bolt and rotate / invert until you get minimum hum.
This hum really was pretty bad, I cannot believe a procedure as obvious as this would cause such a profound improvement.
I?ve read a couple of posts complaining of hum in solid-state diy projects recently, if you haven?t already, try moving the toroid around / inverted etc, it could be just the cure you?re after.
Justin
Justin
