I have a few guitars modded to make it possible to have the volume always at ten. Basically it is just a toggle bypassing the pots. It gives even a little more output then just tru the pot at 10.
This comes from back in the days where I used to hit these things (gtr that is) pretty heavy and so, when you accidentally hit the volume and it turns down to 8 or so, you loose the overmaxed out gainposition where it all happens. Also, I could have a kind of memoryposition to switch back to cleaner sounds by having the volume in and out. Way easier then trying to find the right spot when in 2handtapping stuff and arps all over the neck then putting it right where you want it. Easy mod but very usefull for speedy stageanimals :thumb:
Also an easy feedback killer when having too much gain to be healthy inbetween songs (as is the volumepot itself)
Tony.
