Thanks to all that helped me fixing my Soundcraft Series 600.
Well, the powersupply problem is fixed. What would be the next step?
This console has not been used for a while. It's a bit noisy. Some channels sounds like a nice campfire when I put the faders at max.
Should I start with replacing all the caps?
Would a op-amp upgrade make things better?
...and also....
The hipass filter is set to 100hz. I would like it to be lower. Can I do this with simply changing the values of the resistors and caps in that filter section?
Thanks again
Richard
...and also....
Thanks again
Richard
