Hi guys-
Ive got a project Ive been going in circles on, wanted to get an opinion on a bussing arrangement.
Im building an 8 channel mixer using basically 8 api 312 cards. I have direct outs on each and then plan to use the unused tap on the output transformer to feed a passive mix buss using (hopefully) transformerless input 325's.
My primary application for the mixer portion is most commonly going to be used for summing 2 or 3 channels (while using the others direct out and muted off the mix buss) much more commonly than mixing 8 inputs to 2.
Ive been thinking alot about the "best" way to setup the mix buss to fit my specific needs. This is where I could use some feedback or suggestions if anyone has any.
Ive been planning on taking the feed from the output transformer to a slugged dual pan pot and running the output of that pot into a DPDT switch. Ive got the panpot feeding two poles on one end. Ive got the middle poles going to a small pcb with the bussing resistors and that feeds the L/R 325's. I had been planning on putting a slugging resistor on the outer poles for constant impedance on the mix buss. Im starting to wonder however, how critical or necessary this is and this is where I could use some feedback.
The way Im thinking, if Im only going to be summing 2 or 3 channels at any given time, wouldnt I be at an advantage to not have the entire mix buss loaded down so I could use less makeup gain from the output amps? I dont mind having to fiddle with the buss output gain as I add or subtract channels from the buss if it means better sounding output from the box. If I dont have constant impedance on the passive buss though, is that the only drawback that I am going to have?
If I dont maintain constant impedance, will this screw with the bussing resistor value Ive chosen to use? Is level the only thing that is subject to change on a passive buss that doesnt have constant impedance? Can frequency response be efffected as well?
If you were in my shoes, for the application Ive described above specifically, whats the best way to tackle this to get the best sounding performance off the buss. I dont want to bring up a bunch of noise if I dont have to, but Im not sure how not having constant impedance will savagely effect things.
This is the last you guys will hear of this, Ive been posting about this stupid project for like 18 months or so, Im finishing this thing up very soon, this is the last stumbling block I hope.
thanks in advance
dave
thanks in advance
dave
