B*A*E Power Supply 5 pin XLR pinout?
Helsing
San Diego, CA
Im building an external power supply that Id like to be compatible with the B*A*E modules. Does anyone know the 5 pin XLR pinouts for the +/-16v and 24v external supplies?
Helsing
Thanks Pat,
The API makes sense. Thanks
The Neve PSU is strange because there should be 48,24 and 0V. Could you try testing the supply using the chassis for your multimeters ground reference and then rechecking the pins? There should be 48v, 24v and 0V somewhere in there.
Helsing
b*a*e blue PSU pin out
(to read 48V and 24v, set multimeter at 200 range DC)
PINS
5 red    48VDC
4 n/a
3 n/a
2 orange 24VDC
1 black  COM
Unit is 1.14A
Led Orange = 48V on
Led Red    = 24V on
