keeno
Hi, I?ve a modification on my Trident 80B called ? Analogue switching for modified mixdown facility? so I can route the monitor section to the remix bus via dip switch. The signal passes a CD4066BE chip before it goes to the remix bus. When I compare the monitor channels to the input channels they sound a little bit flat. Does the CD4066BE degrade my signal? Is there a replacement for this chip ? thanks a lot ?k.
