hello, there,
There is unfortunately no such thing as a "Universal" compressor. nothing in my arsenal works in all your requested applications. There are other implications as well when choosing something to build. ie cost and ease of build/experience required/equipment necessary. If you have plenty of money, and are not scared of lethal voltages, you could build a La2a copy. Awesome on vocals, fat on da bass and, um, about as much use as a chocolate fireguard on drums(IMHO). if you don't mind something a bit more complicated to set up, an 1176 might fit the bill. Not my favorite compressor to say the least, but very very popular, versatile, good on bass, vocals, and best of all, great on kicks and snares. if you want something for mix-bus or drum sub-bus, then the G-SSL should be your port of call. easy to make, cheap and awesome! Recently i have been using one on vocal sub-groups, and even on a ld vocal -( f@@king great btw). Should sit nicely on a bass as well, but i've not tried it. G-SSL is very versatile, flexible, 3 ratios, switchable attack/release - here I am talking myself into recomending a mix bus compressor as an all rounder! Kinda makes sense tho', if you think about it! Won't cost a fortune, and if you don't like it on your bass, at least you've gopt something awesome for the drum bus, mix bus etc.
Forsell is amazing, but very transparent. would take the lumps out of your bass wonderfully, but I suspect that you would probably like to "hear" some compression going on.
Haven't tried the What yet, but I guess that like the Forsell, being optical will make it very transparent, which is not always what the doctor ordered, ironically.
Blah Blah Blah,
ANdyP
or you could build them all, and have no friends/social life/sleep likr the rest of us saddo's . . . . :green: :green: :green:
