owel
I was cleaning up some wiring on my Neve 1272 project inside the rack chassis. I forgot to hook-up the gnd wire to the chassis.
When I plug-in a mic, turn on +48V phantom power, I heard AM radio. If I touch the chassis, the AM radio goes louder and softer. So I left the room to get some alligator clips to temporary ground the chassis to the GND wire.
When I return to the room, I smelt something burning. I quickly turned the unit off, and now the channel won't pass audio. Totally dead. I traced the burnt smell to the 2N3055 power transistor.
The other channel works fine.
Question: Why would the 2N3055 burn out in the other channel? In the past, the chassis was ungrounded, but my preamp didn't burn up, nor did i hear AM radio. There was only slight hum.
The only thing I can think of, is one time in the past this same transistor smoked during my initial power testing. But after the white smoke cleared, I tested the unit and it was still working fine. Maybe the AM high RF oscillation finally burnt out the power transistor to its final death?
