Hi all,
I've been working on the Hamptone design JFET preamp design from Tape op a year or so ago. in the schematic shown, he used a 5K taper in between the two FET gain stages. He said that you could add another taper in order to crank the input gain and lower the output gain to give the preamp a input drive type distortion. TO do this, would you put the extra taper prior to the the first stage or after the output stage?
