Jonathan Hayward
Jung regulator and other "fancy" psu's
« on: July 05, 2004, 07:31:11 AM »
did you mean this, there are good threads on this at diyaudioforums.
http://www.reed-electronics.com/ednmag/archives/1997/010297/01di_03.htm
An AD797 as a regulator. Love it.
sismofyt
« Reply #1 on: July 05, 2004, 08:03:46 AM »
sismofyt
« Reply #2 on: July 05, 2004, 08:05:17 AM »
Sorry, those diyaudio.com links are dead because they changed server..   :cry: I'll try to dig up the Super Regulator thread..
sismofyt
« Reply #3 on: July 05, 2004, 08:07:22 AM »
Here it is; (75 pages though, but it's a good informative read!)
www.diyaudio.com/forums/showthread.php?s=&threadid=20937
There are also members there who sell PCB boards..
sismofyt
« Reply #4 on: July 05, 2004, 08:35:27 AM »
For something different, Rod Elliot has these two designs that are also very nice. I don't use any super regulators myself, I prefer something like these two if I do need regulation;
Shunt; (scroll down, the line amp is exellent too, btw :wink: )
http://sound.westhost.com/project37.htm
Capacitance Multiplier:
http://sound.westhost.com/project15.htm
You could use a zener instead of the 12 kOhm resistor to get a specific voltage. I like at least 10 Volts on top of the zener voltage. Try running as much current through the zener as possible, that helps keeping the noise down.
Both designs benefit from additional LCR filtering :grin:
neilium
« Reply #5 on: July 05, 2004, 01:32:57 PM »
Welborne labs offer a variation of a Walt Jung/Gary Galo-designed power supply in kit or bare board.
http://www.welbornelabs.com/ps1.htm
-Neil
BODY MASSAGE!!! http://media.ebaumsworld.com/gijoebodymassage.mov (>1 meg download)
DrFrankencopter
« Reply #7 on: July 05, 2004, 04:40:17 PM »
In one week I will be finished the layout for improved Jung regulators, and I have a little text to go along with it. This was all meant to be part of my improved SSL comp project, but I figured the P/S would be useful for other projects, and have not tightly integrated it into the SSL layout.
I already have the +ve regulator layed out, and just need to set up the negative reg.
Kris
daArry
« Reply #8 on: July 05, 2004, 04:42:28 PM »
nice1 kris  :guinness:
ytrehalf
« Reply #9 on: July 05, 2004, 04:49:57 PM »
This is something that I am really interested in as well. I would like to build a few high quality, over-spec. powersupplies and get rid of my cheap supplies, and also not have to worry about new supplies every time I build another box.
I can't see the sense in obsessing over having the correct transformers and components for these projects and then cheaping out on the power supply.
peranders
Re: Jung regulator and other "fancy" psu's
« Reply #10 on: September 19, 2005, 09:28:19 AM »
Quote from: "Viitalahde"
Could someone source me to the Jung article and maybe other worthy designs too..? I once tried to find the Jung regulator article but failed..  :?
Search no more:
http://www.waltjung.org/Regs.html
You could also check my regulator pcb's  :grin:
/Per-Anders
robomatique
« Reply #11 on: September 19, 2005, 11:14:47 AM »
Quote from: "DrFrankencopter"
Kris
Will you sell these PCB's? Would love to have some around.
Robert
"Trying is the first step towards failure."
-H. Simpson
peranders
« Reply #12 on: September 19, 2005, 05:22:09 PM »
See my homepage  :grin:  You may also check out Andrew L Weeks pcb's not bad either.
http://www.alw.audio.dsl.pipex.com/jung_schematic.htm
/Per-Anders
daArry
« Reply #13 on: September 19, 2005, 05:47:00 PM »
Hey,
I layed out some pcb's not so long ago but still aint got round to testing em yet - only 1/2 stuffed the + version so far...diy gloves hung up of late :(
I did post the initial layout in here but got no response so went over to diyaudio and got some feedback - peranders was one of the doods who gave some layout pointers...;)
Here's and overview of em: (top +  bottom -)
I've layed out the I/O and ground pins on a standard 2.54mm grid so can just sit it on some stripboard for simple hookup...
peranders
« Reply #14 on: October 13, 2005, 04:16:21 AM »
I have made a super regulator power supply. What do you think?
daArry, have you built the regulators now? Works good?
/Per-Anders
bcarso
« Reply #15 on: October 13, 2005, 05:07:19 AM »
Do you have any problems of mains hum injection due to the proximity of the transfomer?
peranders
« Reply #16 on: October 13, 2005, 05:11:04 AM »
No, I haven't noticed anything yet.
/Per-Anders
peranders
« Reply #17 on: October 13, 2005, 05:31:25 AM »
"Sensitive" circuits will probably gain more than buffers, tone controls and such.
/Per-Anders
Last post July 18, 2007, 04:57:24 AM
by Kid Squid
Last post January 18, 2009, 01:59:21 PM
by kato
Last post February 15, 2011, 12:55:00 PM
by barclaycon
Last post March 02, 2020, 04:58:59 PM
by ruffrecords
