So I?ve seen two means to reference the input to ground on the API 312 (as example).
http://www.waltzingbear.com/Schematics/API/API_312.htm
With a very large resistor (R4 as 100K) followed by a very large cap(C5 a 1,000uf) , the cap blocking very little of the signal so the resistor must be bigger (?)
Or
A smaller resistor (R4 at 5-10K) with a very small capacitor (C5 as 50-100pf) the cap allowing very little of the signal to pass so the resistor can be smaller.
Both seam to reach about the same result. :?:
As this will come up with almost any opamp project I am wondering what the advantages or disadvantages of each approach is,
I could see using this as a low pass filter but the values in both cases seam to extreme. What would lead you to go one way or the other? I will play around with this, this weekend, but are there differences that may not be readily apparent to the ear?
[/quote][/list]
Or
[/quote][/list]
