I ioaudio Well-known member Joined May 11, 2005 Messages 2,087 Location vienna/austria Aug 11, 2005 #1 cut out from an old studiomaster first two channels got two sowter instead of the input caps.
jensenmann Well-known member Joined Oct 10, 2004 Messages 2,857 Location Karlsruhe, Germany Aug 13, 2005 #2 Did you put the Sowters in or are Studiomasters fitted with them??? Jens
I ioaudio Well-known member Joined May 11, 2005 Messages 2,087 Location vienna/austria Aug 13, 2005 #3 i put them inside. firts two channels only.
R rodabod Well-known member Joined May 12, 2005 Messages 2,896 Location London Aug 13, 2005 #4 Hi, Interesting stuff. What advantages have you found with using the Sowter input transformer? Does the transformer give you much extra gain? Also, which model is the transformer (or ratio). Thanks.
I ioaudio Well-known member Joined May 11, 2005 Messages 2,087 Location vienna/austria Aug 13, 2005 #5 the ratio is 1:1 , so no extra gain. its a sowter 3603. it´s more silent with the transformer, as the input stage is fully balanced now. (not by more-or-less matched input transistors any more)
SSLtech Well-known member Joined Jun 3, 2004 Messages 5,447 Location Florida (Previously UK) Aug 13, 2005 #6 According to Bill Whitlock, the CMRR should be vastly improved... Keith
