pmroz
Hi all, another lo-fi question. Saw Jakob's splitter design in this thread
http://www.groupdiy.com/index.php?topic=6619#img_7751
Looks like a good splitter for this pedal doohickey I got asked about:
A guitarist friend asked me to figure out a volume/pan pedal (similar to EB 5165) that doesn't suck tone. BTW volume/pan makes 2 signals out of one, then pedal varies output from all output 1 to all output 2, blending the 2 on the in-between settings. Each output goes to a separate amp (Fender Twin and Roland JC-120 in this case). It can also take 2 signals and control L/R for stereo output, though he doesn't need that.
He gave me a volume pedal he wasn't using to mod. At first I was thinking the signals would have to be combined electrically, but when I opened up his pedal and saw the pot connected to a wire, I had a flash of old-school mechanics. All I need to do is split the signal, then mount 2 identical pots on the same shaft (one would be opposite the other, so opposite rotation) and bingo.
Question... if I followed 2 outputs of Jakob's design with a pot each, should the value of each be 1M? 500K is more common, but may be responsible for the 'loading' we've read about regarding the E Ball pedal.
Also, the EB has a pot labelled 'min vol' which I'm guessing is to trim the sensitivity of the pedal swing and zero it at the end of swing(rotation). Maybe this is to fine tune the loading? So if I put another pot in series with each 1M/500K pot for 'trim', what would be a good value?
Input to the pedal would come from a Vox Valvetronix board, last in his chain. And he uses both active and passive guitars, if that matters.
Any ideas?
Any ideas?
