Cainester
Midas Venice Mods
« on: August 22, 2005, 05:29:24 PM »
I am going to make the direct outs of my mixer pre eq and pre fader.  I called a dude @ har_m00n I think, and he sent me the complete schematics and modification pdf's.  Only one problem.  The modification page has no option for pre eq on the dir out.
By looking at This Schematic can this be done easily?
I think I'm going to have jumper from the pre eq to the dir out.
Will that work?
Caine
Here is the Modification page.
ioaudio
Midas Venice Mods
« Reply #1 on: August 22, 2005, 06:44:15 PM »
on the schematic there is an on/off for the eq. simply turn it off?
if you want to use the eq on the mix but bypass it on the direct out,
make a bridge from l1 on the eq-on/off to the direct out.
Coldsnow
Midas Venice Mods
« Reply #2 on: August 22, 2005, 07:34:22 PM »
Any way of making the montitor sends to be post fader?
ioaudio
Midas Venice Mods
« Reply #3 on: August 22, 2005, 07:48:03 PM »
Quote from: "Coldsnow"
shure. just connect the left side of r62c(mon1) and r64c(mon2) to the "POSTAD3" instead of "PFAD3" line.
Cainester
Midas Venice Mods
« Reply #4 on: August 23, 2005, 09:37:15 AM »
Thanks for the reply ioaudio.
I'll let you know how it goes.
Caine
Cainester
Midas Venice Mods
« Reply #5 on: August 25, 2005, 09:25:40 AM »
I started on the mod last night, and I did not realize that I would be cutting a pcb trace.  That is exactly what the instructions say to do, but I guess I didn't think about it.  The trace is pretty difficult to cut.  I had to dig a razor knife into the board and cut a little trench before the trace was completely sevored.
There is some sort of laminate over the trace, and a very small space between the solder pads.
Is there a better way to cut these traces?
I thought about scraping the laminate and board with a pick until I could get some close snippers in there.
Any suggestions?
Caine
adrianh
Midas Venice Mods
« Reply #6 on: August 25, 2005, 06:00:06 PM »
Caine;
You are doing it exactly as you need to do it.
Cutting a "v" is the best method.
Use a very sharp knife.
Use a magifying glass to inspect your work to insure
it is done correctly and you did not damage anything.
Do not worry you can fix the trace if you mess up.
Cut the trace and quit fretting. Enjoy your new mixer.
Cainester
Midas Venice Mods
« Reply #7 on: August 25, 2005, 09:47:33 PM »
That was a piece of cake.  :grin:
Thanks for the help adrianh, and ioaudio.
Caine
Last post May 23, 2007, 05:12:51 PM
by Purusha
Last post August 23, 2012, 09:34:56 AM
by Siegfried Meier
Last post April 07, 2018, 09:51:10 AM
by arson
Last post September 17, 2019, 02:52:36 AM
by gyraf
