The first compressor I got for my then new little studio was a dbx266XL. It was cheap and it was better than the software version in Logic. I later discovered that it sucks and that the Logic comp just suck even more. Hehehe Well, it's been sitting in my rack anyway and I've used it where I HAD to and then of course just gently touched the material with it. When you know it's limits you can use almost anything with an ok result.
However, now that my first GSSL is almost ready and I'm going to build another immediately after the 266 will be pulled out of the rack for good. I have a few RNC's and a couple of the original dbx163's and a 163x, a couple of other ones and have gotten better software ones as well.
I too am thinking about this LED meter solution and since there's 2 in the 266 plus some quite cool on/off buttons with square LEDs in them, and a back panel fully loaded with XLRs, parallel jacks and all I'm thinking about scrapping the unit and re-use as much of it as possible.
Can anyone tell me beforehand if the LED meters will be unusable for use with the GSSL or will I have to open it, post pictures, find schematics and so on before anyone can tell me what I can and can't do?
(The unit has both balanced and unbalanced inputs so I'm already considering that maybe that's all taken care of on separate PCBs in the unit and maybe I can leave it in...? We'll see...:razz
EDIT:
Ahhh, re-reading some of the posts in this thread I can see that I will have to measure my way around to find out how the LED meter cirquits will react to what they'll be fed from the cirquit in the GSSL...
