You said pentodes, but if you'd like to try a dual triode, the output stage of this line-amp drives a 600-ohm load to rather high levels via a 2:1 output transformer.
http://electronicdave.myhosting.net/miscimages/nydave_lineamp1.gif
The output stage (V2) could be adapted for use with other amplifiers as long as you provide the necessary DC bias of about +130V on the grid.
