chrissugar
I started to play with the idea of designing a complementary symetrical jfet opamp and at this stage I tried some simulations and it works. For this simulation the closed loop gain is aproximately 100 [because of the feedback resistors 100 ohm and 10kohm] and as you can see the output voltage is 100mV for 1mV input.
I would like to know what the big proaudio gurus think about it.
I was interested in this topology because it has the advantage to cancel some nonlinearities because of the symetrical structure compared to the usual designs.
For the input jfets I think about the 2SK389 and 2SJ109 and for the rest the 2SJ74 and the 2SK170. I supose if the input fets are paired the 2SJ74 and the 2SK170 will work.
Hope soon to make one opamp on the breadboard and tweak it.
So, Fred Forssell, John Hinson, PRR what do you think about it and how it can be made to work in the real world.
Here is the screen capture.
chrissugar
chrissugar
