1:1 600ohm tx
I'm working on a passive type eq in the 500series format.
So needs to be small, preferably PCB mountable, compact enough to fit in 500 series.
High quality...must be great sounding!
Hope that helps...D
well, it's about the same... edcors don't have "shielding"...they do have copper tape on the outside (for an extra charge) but it's no 30dB shielding can. Check out the mx or mxl series. MXL is just larger, uses m6 steel, mx uses super q 80% nickle.
