> I need a mic splitter for making preamp comparisions using the same mic and source.
Then you are adding the splitter-sound to the whole mess.
Just make a Y-cable, no fancy stuff. Disconnect the Phantom on one of the peramps so the mike won't get hot.
Transformer splits are often essential when you have a monitor PA board, a house PA board, and a recording board, some of them transformerless, all fed from different legs of a funky cow-palace electrical supply.
It really should not be a problem to just Y-connect two preamps fed on the same power and feeding the same monitoring system all in one studio.
Some small problems (not solved by most splitters): the mike sees a lower impedance and may sound different. The two mike inputs can interact: FET and tube preamps probably won't but two good BJT inputs will inject noise current and increase total noise level, and a really bad BJT could inject distortion or odd impedance curves.
