Hi All,
Just finished two EZ1073 units which went well, both units are working.
However, a stereo test quickly showed an approximate 10db variation between the units on line inputs. Mic pre is returning the same signal gain.
With a -12db test tone, the first unit returns a -12db signal which is great. The second unit is returning -22.
I've tested all cables and various inputs/outputs on my Apogee Ensemble but all render the same result; second unit is 10db down.
Pulled the unit in question out and checked all solder points and work. Double checked the calibration as recommended in the build instructions on both units and all is as it should be.
Does anyone have any ideas what could be causing this? Is there any further point values I can be checking to narrow down my fault?
Any advice from you kind folk with more knowledge than I would be much appreciated.
Thanks in advance.
Rosko
Thanks in advance.
Rosko
