Reply to thread
I've never used a Rev. A but that definitely doesnt sound right.
What's the history of this build? I'm assuming you're not the builder. Did you purchase this as 'working'? Does it sound bad when GR is turned off? I'm assuming it does.
I'd first try to run through calibration and see how far you get and then check voltages to those on the schematics to get an idea where things aren't right.
You'd probably have better luck asking in the thread I mentioned above.
